heebsk
Getting ready to have my basement finished and I want to setup a home theater with a projector. The room will be more of a rec room instead of a dedicated HT, so I need to factor in a few more things. I will also be watching sporting events, with some lighting although it will be controlled on dimmers. The room will be very large, but one section (18x20) will be the HT area whereas the back portion (14x17) will have a bar and gaming area. Only two small windows that can easily be covered up.
I have 9 foot ceilings, and I plan on ceiling mounting the projector. The viewing area will probably be about 15 feet from a 92" fixed screen. I'd like to stay under $2000 for the projector, so I can spend more on audio.
Now to the decision on the projector. If I go the DLP route, I'm looking mainly at the Optoma HD72 or the Mitsubishi HC3000u. Both compare fairly well on features and price. If LCD is my best choice, then I'm thinking about the Panny AX100u or the Sanyo Z5.
Overall, I probably have around $5000 - $7000 to spend on my setup, but like I said I am looking to have a large portion of that for the speakers.
If anybody has any other comments or thoughts on the rest of my potential component choices I'd be glad to hear them as well.
DVD - Panny S97 or Oppo ?
Receiver - Denon 2807 ?
Speakers - Not sure, but surrounds have to be in-ceiling
Sub - Either SVS or Velodyne
Thanks in advance!
Thanks in advance!
