Need help with house/ outdoor speakers.
df4801
Hello all,
Can someone please offer some suggestions.
Looking to get 2 outdoor speakers, 4 in ceiling speakers and 2 in wall's.
The 2 in wall's will be for TV so a little higher quality needed. But the others are just for background music, so looking for best bang for the buck.
Thanks!
Sheep
Sheep
The one area I have no experience in...
I have failed you...:(
SheepStar
L
LOUMFSG
df4801 said:
Hello all,
Thanks!
I recently bought outdoor speakers and I went with PylePro PDWR63 speakers. Here is the info:
Rugged Plastic Enclosure
6.5'' Long Throw Woofer w/ 60oz Magnet
1'' Polyamide Dome Tweeter
150 Watts RMS/350 Watts Power
Frequency Response: 50Hz-20KHz
Average Sensitivity: 94dB @ 1W/1M
8 Ohm Impedance
Spring Loaded U Mounting Brackets Included
Dimensions: 9-1/4''W x 13''H x 7-1/4''(D)
http://www.pyleaudio.com/itemdetail.asp?brand=pylepro&cat1=Home Audio&cat2=Indoor/Outdoor Speakers&model=PDWR63
I like these speakers for a couple of reasons:
Frequency response down to 50Hz (nice full sound for an outdoor speaker)
94dB sensitivity (very effecient)
Nice construction (they look like they will handle the weather well)
The price - they can be had on-line for $79.99/pair (about $99 shipped)
One negative, they are a little on the large size, so if finding something that blends in visually is your priority, these might not be the best fit.
But they sound good, certainly if you are only looking for backround music, and for those occasions where you want to crank them, they can handle it. And for the price, they are hard to beat.
Good luck with your search
