Need Help With Home Theater
K
kyle2oo6
Hi Im having a problem connecting my digital cable box to my DVD/Home Theater system. I am wanting to play the audio of the digital cable through the speakers of the home theater system.
jcPanny
jcPanny
Digital audio connection
Use a digital optical or coax connection for audio from your cable box (and DVD player) to the receiver. You can either directly connect the video to your TV or route it through the receiver using component video, etc.
Also, check out the Beginners section of the forum for an index of several articles that will help you connect and set up your HT equipment.
