Hi All,
I recently purchased a powered sub to upgrade from an old passive sub I picked up in '93. What do you do with a old piece of equipment? Take it apart and see what makes it tick, of course! When I took out the speaker and crossover I was impressed with the build quality of the cabinet- 3/4" MDF for the sides, top, and bottom and 1 1/8" for the front baffle. The cabinet has cross bracing in the front and back and a brace running vertically through the middle of the cabinet. I would like to put a new driver and plate amp in this cabinet if it is worth my time and money. I tried various free box software programs, but most of them work with inputing the driver and spitting out box dimensions instead of the other way around. The internal volume of the cabinet is 1.65 cubic feet (taking into account the bracing) and the port is 4.25 inches in diameter and 13 inches long. The recessed cutout is 10.25 inches and the driver cutout is 9 1/8 inches. The baffle is 11 inches wide, so I'll have to stick with a 10" driver. I was looking at the Dayton Quattro 10". Thoughts?
Also- The original driver is foam surround and there are no parameters printed on the speaker.
