That is letting you know the continuous and maximum power levels that sub will handle before something fails.
I am not sure the best method to wire that one?  I would run the amp in normal mode (not bridged) and run one channel to each side (it is a stereo amp), giving you the same effective results as bridging the amp if it was a single voice coil.
The difference between a "regular" amp and a sub amp will usually be that a sub amp has a few more controls to make adjustments for the sub (crossover, volume, phase) and more expensive sub amps may have additional features.  When using the preamp out from the receiver, the receiver handles the crossover, but it is still a good thing to have; this amp has one.  It also has volume control so you can adjust it separate from the receiver (can be important for calibrating the sub).  Phase is the only thing you wouldn't have with this one, but your sub is in-wall, so hopefully phase isn't an issue.  Reversing the +/- would be your only option if it is; only giving you the two choices of 0 or 180.
