I strongly recommend skipping the .75cuft sealed for home theatre, because I've been there! I just sold (yesterday) my Alpine Type-R 12 (swr-1240) in the .75 enclosure I got it in in the first place, it was anemic and took some eq'ing to get a balanced sound out of it. YMMV, but I'm in a large 12x38' room, if you have a smaller room it may fair better.
I had it in a larger 'throw together' ~2.25cu ft vented enclosure that was sounded quite a bit better for most of it's life. Don't underestimate the amount of port area you'll need though, a single 4" pvc was not nearly enough vent area, and she chuffed badly past 150w, and was clearly hitting massive amounts of compression past a few hundred watts. Even then, keeping it pre-chuffing I was getting more useful output than in the small sealed box without exceeding the drivers power rating. The small sealed box faired well with 1000+w... but that is a recipe for a short life span.
annuaki's suggestion of 1.25-1.75 cuft sealed is likely a great one, but as he said, try and model it first.
