Within that budget, I will recommend these
HERE
They are great speakers, built extremely well for the cost.
Oh by no means can they compete with speakers costing 3 times as much.
But I still do not know how they can build a speaker of that quality for as cheap as they do.
I had a set, just for testing purposes, I do recall they had quite good lower end on them.
However I do recall them with a hole in the midrange.
I'm sure with some modification (extra bracing, internal fill, etc..) they could be improved upon.
And although I have not heard these surround speakers, I have been told for the cost they are very good.
These here
Anyhow, it was just a suggestion considering the current limited budget.
