-_-
shadyJ is
on a crusade. Follow his advice only if you're OK compromising on the lowest rumbles of your movies. (Actually, that's a worthwhile thread for you to read, even if I don't agree that his recommendation in
this thread is the best fit for you.)
I'd say start with three WaveCrest HVL-1 for LCR (left-center-right), a Dayton Sub-1500, and a decent receiver. That'll leave you some room within your budget for speaker wire (Monoprice 14awg, get 100' spool) and some stands for your speakers. This setup will play lower than the Focal monitors while still sounding good for music, whether you listen to it or not.
If you can wait a couple of months before you start, the ELAC Debut series promises excellent sound quality for a limited budget as well.
The thing about speakers being good for music is, if a speaker sounds good for music, it'll sound great for movies. The reverse is not always true, though.
And handyman skills aren't necessary for a 5.1 channel system. You'll probably have your front 3 channels + sub near the receiver, so just run the wire out in the open. You can hide it using cable management such as Wiremold, available at Home Depot or any other local home improvement store. To run wire to your surrounds, you can just cram the wire down between your walls' shoe molding and carpet, then run it up the wall to each speaker using Wiremold again. Here's an example of what it looks like:
