It's also a piece of keeping sound from the outside getting INTO the theater and raising the ambient noise level of the room thereby reducing apparent dynamic range. It's only a portion of the solution though. You also need to deal with any holes (electrical boxes, switches, lights), doors, and the air handling system. If you don't do all of those, then don't bother with the extra drywall and green glue as the others will defeat the purpose.
Bryan
