Need help pairing a sub
KASR
KASR
Ok, so I want to pair my existing sub - but unfortunately I can not find the exact sub that came with my 5.1 set (you can see it here: Polk RM6750)
So the question is: is it better to buy two separate matching subs for my Polk satellites or can someone recommend a Polk that matches well with the existing one. Thanks in advance!
Z
zumbo
Sub doesn't have to match, unless you just want it to have the same name on it.;)
jostenmeat
Its generally true, except that smaller satellites might benefit from subs that maintain linearity into higher frequency range. Of course, if one is bumping up the x-over, you'd want the sub(s) close to the sats.
