Need help on new system for a condo??
connecticane88
I am buying my first home audio system and don't know very much. I have just been reading reviews mostly. My living room will be 17 by 18 and I will be wanting to do everything with this system(movies, videogames, music, and feeling like I am at the game). Since i cant go overboard with power (condo)I didnt know if some of the expensive stuff was unneccessary. I was leaning toward a denon product(1906, 2106, or 3805), and then I have only heard the boston acoustics vr1. I was also looking at infinity primus 360, or beta 50. I was just going to start off with two fronts, and then add things later on. I wanted to make sure I that I also got something that I could easily add on to. So am I headed in the right direction or should I start over. Like I said its a condo so I dont want to piss the neighbors off but would like a nice systemto enjoy. Ididnt know how much of a differenc ein sound the receivers would make since I cant go too too loud. I dont have too many stores around me to go and listen to that many brands. So what should I do, any advice would be appreaciated. Thanks
jaxvon
jaxvon
Welcome!
The choices you listed are all decent, but you should definitely not limit yourself to just those. Try to find some hi-fi shops in the area and start listening. I'm sure you can find something in your budget that sound excellent. Your approach is a good one as well. It's much more satisfying to buy good speakers a few at a time rather than go all out and get crap.
I do have a question though: What is your budget for the project right now?
connecticane88
I wanted to stay around 5 - 7 hundred for the receiver, and around 300 - 600(pair) for the speakers. Are there a lot better speakers or receivers than I listed. I dont know any brand names or anything. I know I need to listen but most of the websites on have certain products. I have no idea what to ask for.
