Need help on ident of 7 inch speaker
Carl06c6
Was looking at these 7 inch woofer/sub ?? Speakers on ebay and tryin to figure out what boston acoustic unit they may have been meant for , and if subwoofer or woofer.. Any help would be great.. Tryin to find spec's
Here is link to them on ebay
http://www.ebay.com/itm/Boston-acoustics-7-speaker-Model-BUNITY2001/251702107810?_trksid=p2045573.c100034.m2102&_trkparms=aid=555012&algo=PW.MBE&ao=1&asc=20131003150253&meid=b74d2a9fe1e944038f7b1214077c0c0f&pid=100034&prg=20131003150253&rk=3&rkt=8&sd=251715783807
Carl06c6
I have a email sent into seller,, but it looks to me like Bostons, 8" WOOFER. from possable dt-7000 systems ????
zieglj01
zieglj01
Looking for woofer's for home audio [ speakers ]
If you are talking about your Optimus LX tower speakers - they are not made for
a simple drop in. The crossover also needs to be redesigned.
crossedover
crossedover
Still looking for info on the woofer/subwoofer, info-- from orig question...
Here is what would help. Explain exactly why you need the info, ie you have an old Boston acoustics speaker and need a replacement or I'm looking to build a speaker or I'm just curious about these mid woofers. It's very helpful to the community that is willing to give you the "right" help.
Carl06c6
Just need info as may be building..... Didnt think i need to explain what i may or not build. Was just looking for info on a certain speaker...
I guess no one knows.. Ill do what Zieglj01, said contact boston acoustic.....
crossedover
crossedover
Reason being is if BA can give you the TS parameters they may not be accurate. Drivers typically need measurement to get an accurate set of numbers. Just going of the shelve with numbers other than subwoofers may prove a lesson fruitless in practice.
