Need Help, Mounting center channel on top of T.V.
cropduster1
Just got my Axiom vp150 and trying to place it on top of my Samsung DLP 56". The top of the tv is very thin (only 2") so balancing it on the top is not very stable, plus I have a two year old and don't want it to fall. My tv is in a corner and I thought of putting a shelf across the corner just a bit higher than the tv.
Any other bright ideas or suggestions??
thanks
thanks
Clear fishing lines from the ceiling? A stand behind the TV with an arm and platform extending forward?
cropduster1
Thanks guys,
I've decided to bust out the saw and nailgun and build a custom entertainment center that will work in my corner. It will house the tv, all a/v gear, center channel, and have a few cubby holes for the wifes "stuff" aka. "junk". Will post a picture when I am finished. Just don't hold your breath!!
thanks
Swerd said:
His DLP tv is just too thin without that rear TV projection box for a conventional tube neck so I doubt this one will do ;)
Unless those rear legs are long enough to sit on the table the DLP is on. Now that would work. He might even be able to replace the stock legs with longer ones?
Bur then, if he was a bit handy, he could make one based on that design ;)
