Hi, I am currently wanting to buy a new Onkyo Receiver and hope to use my existing speakers. The receiver I would like to purchase is the Onkyo TX-SR701 but I don't want to blow my speakers.
I have the following Speakers:
Cerwin-Vega AVS632 Speakers
Frequency Response: 35 Hz to 20 kHz
Satellites Design: 2-way, acoustic suspension
Recommended Power: 20 to 40 watts
Impedance: 4 ohms, nominal
Sensitivity: 87 dB @ 1 watt/meter
Drivers: (1) 1" mylar-dome tweeter
(1) 4" woofer with butyl-rubber surround
Video Shielding: Yes
Dimensions: 8-3/8" x 6-7/16" x 4-1/8"
(unpacked, each)
Weight: 3.3 lb (unpacked, each)
Centre-Channel Design: 2-way, acoustic suspension
Recommended Power: 20 to 80 watts
Sensitivity: 90 dB @ 1 watt/meter
(2) 4" woofer with butyl-rubber surrounds
Dimensions: 6-5/8" x 13-1/2" x 4-1/8"
(unpacked, each)
Weight: 5.5 lb (unpacked, each)
Powered Subwoffer:
8" woofer, bass-reflex enclosure
Amplifier: 100 watts
Dimensions: 14-1/2" x 12-1/2" x 13-1/4"
(unpacked with feet)
Weight: 22.3 lb (unpacked)
You can get more info at the following website.
http://www.cerwinvega.com/products/homeaudiovideo/index.html
Do you think the speakers listed above will be blown away by the reciever I plan on buying?
Thank You in advance for your help.
