Need help in choosing subwwofer for 50m^2 room
bassbear
Hello,
I have a set of KEF q950 + q650 + small teufel sorround speakers (4 pcs) powered by Marantz 5015 in ~ 50m² attic and i would like to extend it in music and HT with subwoofer as F3 of the speakers is 44Hz.
First idea was to just buy svs SB2000 which costs here in Poland about 700$ or klipsh R115sw for ~ 450$ (used one)). Maybe I can have something better if I make one by my own in similar budget. I have plan to use my amplifier T.AMP 1050 MK-X which goes 2x520W@4Ohm (lowest possible impedance accepted, does not work in bridge at 4 ohms).
I have found nice project from TLS guy
https://forums.audioholics.com/forums/threads/dayton-18-ho-ported-build-thread.93086/ with nice driver and f3 at 22,5Hz. Unfortunately in meantime new driver version appeared and after remodelling F3 goes to ~ 28Hz :(
My goal is to choose the best option for low good quality bass in similar budget. Would be nice to find european speaker if possible as e.g. RSS460HO-4 costs over 600$ in Poland in comparison to 429$ in US. This is still fine but possibly there is better option :)
Could any of you guys kindly help me to make proper decision in choosing best driver?
BR
bassbear
Actually STX was my first choice when it comes to budget and local - unfortunately none of woofers seems to have good parameters unless i will use more in one box (but of course I may be wrong).
In general I have heard warm words about beyma and B&C in PA/stage equipment. Possibly they are making also standard subwoofer drivers.
I have skimmed over B&C webpage - did not found any driver which can go lower that 29Hz.
Beyma webpage seems to have better search but not sure what other parameters are the most important here.
I assume you guys know better US speakers so i won't be stubborn on EU ones.
