Need Help - Home Theatre System
N
Navneet
I am looking for some help on buying a low cost home theatre system.
I am told of 2 options coming in F&D which are VFM. But not sure which to buy. Please gp in case you think there are other better performing low cost Home theatre systems, pls let know the option. Thanks
1st option: F&D T-60X. Not sure about the Bass - My room dimension is 22X25 ft
Pros - It can support Optical Input and Comes Close to Rs 12 K.
Cons - Not sure abt audio quality.
2nd Option - F&D - T-400X .
Pros - Good Bass sound. Even cheaper than T-60X
Cons - No Optical Input.
BMXTRIX
BMXTRIX
These look like all in one solutions, which means that if any one part breaks, the entire system is down.
Buy speakers separately from your electronics. Stand alone tower speakers which just need to be connected to an A/V receiver. Then an A/V receiver which has all the connections you need to it.
Not sure what is available to you in India, but the solutions you are showing are ones which I would desperately try to avoid.
On the lower end, something like this wouldn't be a bad starting point...
http://www.amazon.in/Yamaha-Theater-Package-Yht-196-Black/dp/B008LN6BU6/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1474474055&sr=1-2-catcorr&keywords=av+receiver
