Need help getting a good home theatre system
matt48
I'm building a new home theatre system to go along with my Samsung 67'' DLP TV A750 model but I have totally no knowledge in this area. I'm trying to figure out if I should buy seperate components (receiver/speakers seperately) or get a whole system. I will also connect the PS3 to it. I'm not really picky and I don't listen to music everyday. I just want a good home theatre system to go along with the TV and PS3 when I watch BR DVD sometimes. I do want a solid sound quality though, btw it doesn't have to be really loud, what I want is good solid sound when watching blue ray DVDs.
If anyone can recommend me a good receiver/speakers system, I would appreciate it.
My room size is 15 feet wide, 20 feet long, and about 10 feet high, also open to kitchen/dinning room and living room too. My budget is around 1200 bucks for the whole system (receiver/sub/5.1 speakers)
I found this Panasonic SC-PT956 for 300 bucks in costco. Is this good enough for PS3 games/movies experience? I notice the high 10% THD rating at 1000W and 1% THD at 428W. Can anyone tell me the difference between RMS power rating and FTC power rating?
Also, I intend to build a home threatre system starting with 2 of these infinity P362B (130 bucks each) along with a yamaha receiver RS-V661 (330 bucks) as an alternate option if the Panasonic system doesn't satisfy my demand for quality.
Any advice would be appreciated.
BMXTRIX
BMXTRIX
The first thing you want to do is set a budget for how much you will spend. If your budget is $1,200 for the whole system, then plan to spend that much. If you really only want to spend $1,000, then say so - and plan to spend it.
You can get cheapie HTIB systems, like that Panasonic, for less than $300 - even around $100 for some. They generally use speakers that are no better, and sometimes worse than the ones in your TV. They are also, quite often, not using traditional A/V receiver connections, and are impossible to upgrade - and very likely to break.
It should be noted that Denon and most other major manufacturers rate the Total Harmonic Distortion (THD) level at about .1% or less.
For example: http://usa.denon.com/ProductDetails/4239.asp
If you go into the "Detailed Specifications" you will find the 75 watt power specification followed by a check box indicatin that THD is rated at .08%.
1% is typically a maximum THD rating in most magazine reviews - and is high.
.1% is typical for what many would consider a measurement of power.
As well, power is typically rated with only two channels driven instead of all 5 or 7 channels.
At $1,000 you likely can find some decent separate systems using Onkyo, Yamaha, Pioneer, or Denon A/V receivers and some speakers. If you really want to stick with a home theater in a box (HTiB), then one of my favorites tends to be Onkyo with this...
http://www.us.onkyo.com/model.cfm?m=HT-S7100&class=Systems&p=i
Under $1,000 always, typically well under (look online for deals) and compatible with the new HD audio formats from Blu-ray. As well, a zone 2 output (powered) if you want to put an extra pair of speakers in another room (deck/kitchen).
The best part really is that you can switch out the speakers at a later date if you want to upgrade quality - and you can keep the same A/V receiver.
Note: The Onkyo is rated at 130WPC at .08% THD. Far - FAR superior to the Panasonic you reference.
calnbs
The Infinity P362 is a good start for speaker. Currently my favorite budget floorstanding speaker. Skip the HTiB.
