Need help for sound system
  • Thread starter Thread starter Nnardco
N
Nnardco
3
0
1
25
Hey, I got two big 60W speakers (6ohm) from a yard sale and wanted to do a sound system of some sort for my room.
I’ll just use it to listen to music so I figured a 2.1 sound system would do the job.
However idk what subwoofer I should get to complement the speakers well nor what amp to power and connect the speakers by Bluetooth to my phone.
I also have two 14W 8ohm tweeters and two same specs smaller speakers if they can be included in the build I’m happy.
Any help is welcome :)
  • Like
Reactions: Golfx
what speakers are they ? (brand / model #)
Personally, I wouldn't put any real money into a kit using those speakers. Will they make sound, play music, yes. Anyways, are you starting from scratch ? no other components ? what are you planning for a source ? budget ?
why not ? Are they bad speakers ? Tbh I want to spend the minimum so less than 200€ for a subwoofer, amp and Bluetooth
They're nothing to brag about, IMO they would be fine in a garage or work shop perhaps.
good luck, perhaps you'll make out better with more yard sales ...........
If you can give folks an idea of what your budget is you'll likely get some very good recommendations.
