this is a new game for me so all info even if seemingly basic is appreciated;I am in the process of setting up a home theater and desperately need advice;I have just received my speakers , axiom, M80 front R+L,VP150 center,QS8 surrounds: 4 side,2 back, 2 high front,and 2 EB600 subs.I have purchased 4 side surrouds because of the very large dimensions of the room 35x40 and also because the seating will be staggered and varried ( sofas,bean bags, lazyboys) will be in constant flux {4 children with friends etc..}.2 Outlaw amps are on their way 300x7 and 125x7 as well as prepro integra DHC 80.1. Questions abound...How to I connect my 4 side surrounds?the integra has balanced and analog outputs,can I use both at the same time which would give me my 4 side surrouds or is there a way to split my inputs going to amps (14 channels availble);if this is an option do xlr cables exist that are Y config??or are there RCA cables in Y config??I may later on use 6 side surrouds,3 R and 3 L...are there cables availble for this set up??Also when using integra in setting up system are there options for setting up multiple side surrounds??In setup can I independantly set each sub if they are connected to one another by xlr out sub#1 to to xlr in sub#2 instead of using the 2 sub outs on prepro???Please be as detailed as possible as this is all very new to me .At present display is a pioneer kuro 141D monitor but will be setting up projector as 2nd display in next 6-10 months ,any suggestions???
