need help finding proper speaker mount
  • Thread starter Thread starter enigma7
E
enigma7
8
0
0
does anyone have any suggestions on speaker mounts compatible with keyhole inserts? i have ACI Emerald onwalls (15lbs)(link of back plate below) and i'm aware they are designed to be flush mounted but looking to mount them just a few inches of the wall.
Thanks
Sunny
I would contact or visit the ACI website, They may have a bracket option for your Emeralds
i've checked with them but unfortunately they offer no bracket solution for the emerald
You may want to look into some Omnimount 20.0's. They can be found for around $30 ea shipped. You'll have to replace the plate on the back to use them.
I'm not aware of any mounts that match up with your bracket. Had you considered making or modifying something to work with it?
Jack
