Don't try to figure your box and vent dimensions before deciding on a driver. In any case, your vent opening dimension is determined by balancing the vent velocity (ideally keeping it below 17m/s with the intended power levels) and the 1st vent resonance (ensuring it is not within your intended bandwidth).
So to make it easy, select a woofer first, model it, and the rest comes into view.
I would however, know what your maximum enclosure size is that you can live with, then prior to purchase model the driver to determine it will fit, after accounting for vent displacement, etc.
