Leprkon said:
my comments are based on the strengths and limitations of the physical capabilities of the equipment that were asked about and are not just random personal opinions.
Ok, so they are not random personal opinions, but they are not entirely factual either. I'm sure your comments are accurate for
some of the models specifically mentioned, but not all of them.
Since I own the Onkyo and am familiar with all of the models:
- The 702 DOES have amplified zone 2 as does all of the other models in the list. In all these receivers, you can have 5.1 in the main room and zone2 amplified. You only need a separate amp if you want 7.1 in the main zone.
- The 702 IS NOT designed for computer music, if by that you mean the ability to stream mp3/wma - that requires the 801.
- NONE of the receivers mentioned can send digital audio to zone 2. In fact, no receiver other than the more esoteric brands like B&K, Sunfire, etc can.
- The 702 IS THX Select Certified. Sure none of the others are.
- The 702 DOES do video upconversion if you mean 'transcoding'; ie convert from composite or s-video to component. NONE of them can truly 'upconvert'; ie convert 480i to 480p or higher resolutions.
As I said, all receivers in the same class have almost identical features. Only the manner in which they are implemented differs and some are entirely un-user friendly.
Don't send the guy on a wild goose chase based on your own perceptions on which receiver does things the 'right way', especially when your recollection of the differences between brands is not accurate.
