Need help choosing a sub for stereo
AlCapone
<font color='#000000'>I am looking for a good sub with size 8&quot; or 10&quot;, and can go down to 28hz, my budget is around $300. My room is medium size. However, I don't mind to grab a second hand sub. Thansk for your suggestions.</font>
beags
<font color='#000000'>I will swear by this gem. &nbsp;I am no expert in the field but I can tell you that from my own experience listening to multi thousand dollar subs to &quot;home theater in a box&quot; subs this sub burries them. &nbsp;Go to this site and then read what Wes Philips wrote about it. &nbsp;http://www.partsexpress.com/pe/pshowdetl.cfm?&amp;PartNumber=300-739&amp;DID=7
He would be the expert that can accurately put into words what this sub can do. &nbsp;It is 349.00 from Parts express and it is a two hour DIY. &nbsp;You absolutely will not be dissappointed.
Good Luck &nbsp;Josh</font>
K
krazycar
<font color='#000000'>check out the infinity interlude 100s 10&quot; subwoofer. it has a 250 watt amplifier and sounds awesome. it extends down to about 21hz check out the rave reviews on cnet calling it the best sub for $499.00. also check out the reviews at audioreview.com i have one brand new in the box for $200.00 this sub sold for between 450-500. i already have one in my own system and the sound is fast clean and acurate. have a good day hope i was of help.</font>
Yamahaluver
Yamahaluver
<font color='#0000FF'>Check out Yamaha SW-320. Add $200 more and you can get the 800 watts YST-SW800 which has phenomenal performance.
</font>
G
Guest
Guest
<font color='#000000'>Your best bet is probably an Adire Rava ($399) or a Hsu VTF2($499), even cheaper if you buy them used.  They may stretch your budget just a little, but either gives you so much more for your money than any of the Yamaha or other subs, IMO, and I don't own a Rava or a Hsu or have any connection or interest with either company.
Adire Rava
HSU VTF2</font>
Yamahaluver
Yamahaluver
<font color='#0000FF'><table border="0" align="center" width="95%" cellpadding="0" cellspacing="0"><tr><td>
Khellandros66 : Yamaha has some really nice new subs out,
I beleive the have a 270w (website incorrectly says 250 but yamaha.com says otherwise) 10&quot; for around your budget here
http://www.etronics.com/product....id=4206
^ Bob
Funny,
These models are unique to the US as they arent avaialble anywhere in Europe or Asia. Out here you would get the SW-320/800/1500, which have respectively 300/800/1500 watts of output.</font>
