Thanks for the clarification. I'm a little in over my head.
So do I need to be using a 7.1 speaker setup for this to work?
No Or is there a difference, even setup at 5.1, in the audio quality? If I understood you earlier it sounds as though there is but it depends on each person and what they hear.
Exactly
Like I said I'm just checking to see if there is something I can do to improve my experience with my existing and new equipment. Not sure if it helps but here's the manual on the SR7300 recv'r:
http://www.yourwns.com/files/c_sr7300_man.pdf
