Need Help Changing out my LCR
cka69335
I want to upgrade my current LCR speakers for better ones, however there are a ton of brands to choose from!:eek: HELP ME!!
I typically watch 60% movies and listen to 40% music.
When I watch movies I want the new system to make me feel like I in the movie, I think that this is one thing my current set lack. I would like more of dynamic sound, and a wider sweet spot. One of my main complaints of current system is my center -- I hate it. The store said that it is a perfect match but I don't think so. It tends to be weak, and over all tonal sound doesn't match the fronts.
As for music I tend to listen to everything (except country -- no affiance) ;) I would like to hear more dynamics as well as clarity, and be able to turn up with out loosing clarity.
I know everyone’s next question -- "What is your budget?" Well I have 3 budgets listed below; please advise on the perfect set.
$1500
$2000
$2500
Z
zumbo
Yawa will sell you these, which your amp is capable of driving, for $1549.98. All three.
http://www.yawaonline.com/miva/merchant.mvc?Screen=PROD&Store_Code=YO&Product_Code=MBQ_QLS830&Category_Code=SP
http://www.yawaonline.com/miva/merchant.mvc?Screen=PROD&Store_Code=YO&Product_Code=MBQ_QLS330&Category_Code=SP
If gloss silver is not a problem, here is the best deal around:
GR60 and Gold Reference LCR. Click DEALS on the left, and scroll down to Gold Reference. $2498.00 All three.
http://www.saturdayaudio.com/
Otherwise, I would check your local B&W dealer. You may be able to get a 700series deal for $2500 for the front three.
rnatalli
The only way to find what you like is to get out and audition as many speakers as you can. Have you heard speakers before that wowed you? If so, what were they? That'll help narrow down what to look at.
