Need help analysing room correction results
Those are predicted results, or sort of target curves, not the actual results.
The ones on the left are a rough measure of what's being read by the program for that speaker's response, the one on the right is what it is aiming at after application of equalization. Curious, what is setup particularly in terms of speakers/subs?
F
Fuze84
I'm running a 3.1 system at the moment planning to add rears at some point, my speakers are kef q750, center is kef q650 and I have a jamo 360 sub
It looks as if your sub is turned up way too loud!
F
Fuze84
I got -6 on the sub trim after running audyssey , I thought that was quite good, bass was decent, I have posted my subwoofer response also now
That's a decent place for sub trim. I was just wondering if the speakers were combined with the sub for the graphs, but I didn't think so.
The sub must have been engaged as you can see the sub's signature in all the responses.
That would be odd for Audyssey to combine them, nor does it appear that it does; maybe his speakers are in a corner or something.
F
Fuze84
So I moved my setup from my living room to one of my spare rooms, I know it's overkill for the room, but my kids kept touching them!! So yes the speakers end up being close to the corners
G
Golfx
I’m smiling cuz I have a seeming endless supply for grandkids. I had to mount my surrounds up off the floor to protect them from mischief.
