need front speaker advice to fit in cabinet
N
neal
need advice on front speakers to fit my inside cabinet (18"w x 11.5"d x 46"tall) I am running two svs subs in cab. below each speaker . room size is about 15'w x 28' d with 9 foot ceilings . under 4k range, thanks
Chicagorep
Triad can build you speakers to fit in that cabinet
Your problem is that the speakers will have to be designed to work and sound good in that space.
Off the shelf speakers are not designed with your application in mind.
It is actually quite a difficult task to design speakers for what you want to do.
I assume you have something like this in mind.
Pictures of your set up would be helpful
N
neal
tls, yes just like the pic, but my speakers are higher with the subs below in a seperate cabinet. how do i post a pic? receiver is a sherwood newcastle p-965 with a a965 amp
You need to have your pics loaded to a server, like Shutterfly or Smugmug.
When you get the image loaded right click on the image you want us to see. The click on view image. Now copy the URL.
Now find the place in your post where you want to display your picture.
Now left click on the yellow envelope with the stamp on the tool bar at the top of the post and copy your URL to the box and click OK and your are done.
N
neal
tls thats beyound me , i know how to send a pic email
