need basic help with 5.1CH home theatre setup
beginner76
Have managed to connect all speakers & connect cables but middle speaker not working any tips? :confused:
markw
Well, given that to go in, I'd suggest...
1) hooked up wrong
2) receiver not configured correctly
3) something ain't working
skizzerflake
skizzerflake
Try walking through the basic setup on the receiver. Many of them have options to select whether you are using center and/or rear speakers. They also usually have a level adjustment for each speaker. Put on a 5 channel DVD or SACD and put your ear right up to the center. If you don't hear anything, but the speaker is on and level adjusted similar to the other speakers and the wires are correctly hooked up, you probably have a receiver problem.
