Need an A/B speaker switch
Z
ZoFo
Can someone point me to where I can buy a speaker switch that will allow me to A/B 6 speakers? I am getting ready to order some Accends and want to A/B the Front L & R and Center Channel against my Energies to see if I prefer them and I cannot find anything that will work!
Do they make an A/B switch that will allow more that 2 sets of speakers? Do any of them have "Remote Controls" that will allow you to switch between speakers on A and speaker on B?
Thanks in advance!
N
NotherNewbie
speaker selectors
Don't know if you got a reply to this yet..
Niles makes a couple of speaker selectors.
I'm running a SSVC6 - it handles 6 pair of speakers, and allows me to set the individual volume level for each pair.. the inside circuitry makes your amp think only 1 pair of speakers is attached (blanaces the ohms)
There's models available without the volume control also.. I opted for the volume one becuase I run outside speakers in the summer.. and I like them a bit louder.
There's also another mfg that had a unit that accepts 2 sources, so the speakers in one room can listen to something diff than the speakers in another room.
Go onto ebay and search on "speaker Selector".. it should giveyou the niles units and the other mfg.. mine ran around $200
Z
ZoFo
Thanks NotherNewbie!
That is EXACTLY what I am looking for but could not find! :)
