need advice on choosing between subs
arnyplmr
okay, i have my choices of subwoofers down to a
infinity ps212 or a cadence csx-12
both are priced around 300$ which is my max buget price
which of these would be the better choice? it seem as though the cadence is better based on some reviews ive read. keep in mind i will be using this sub for music only, i want something LOUD and fairly clear and not muddy or boomy. Im somewhat of a bass head and i am used to listening to higher powered car subs and i want something that can come close to that sound level but on a tight budget
arnyplmr
wow i had no idea about that website. thanks a lot, a used one just might be the way to go for me
cbraver
The Velodyne FRS he listed is a really, really, really nice sounding subwoofer, especially for that price. The auction says it needs a grill though, might want to check with what one costs from Velodyne....
bandphan
bandphan
adding a little more to your budget and getting a better quality used unit will make you happier in the long run.
