Need advice -- How do you buy a pair of earphones you want if you can't test them?
trelx
So I've been looking for a solid pair of earphones (under $100), not in-ear phones (they feel like Q-tips to me), and not headphones....just something like those earphones that come with your Ipod but sound much better.
Now I can obviously see why stores won't let you test them, because who'd want to wear a pair that's been in 100's of people's ears? That being said I come to you, and look for some advice on a good pair you'd recommend. Quick info:
• I listen to a lot of classic rock/ballads, not sure if this helps recommend a pair?
• I am not a fan of bass, the whole thump-thump sounds people obsess over isn't something I care for much. I like the sounds to be very clear.
• I'd like a pair that is durable and doesn't break easily like the cheap earphones.
• I'd like them to be comfortable.
• I'd like them to be under $100.
I'd really, really appreciate any recommendations or suggestions you may have, including the pro's & con's.
avengineer
How about Grado SR-80i?
Grado Labs | SR80i
Find them on Amazon for $99. They might be a little bigger than you were thinking, but well worth it.
G
Gordon20Hz
ewwwwwww! I hope you're joking...
I concur!
since your not looking for something too crazy I would just look online at your local electronics dealer website see what they have and read reviews from around the web...
