So based on the feedback that changes things a little bit.
Seeking advice on a premium media server setup—prioritizing ease of use, reliability, and support over budget constraints.
Current needs:
- 10,000+ songs, 200+ Blu-rays and growing
- High-quality streaming to theater room and dedicated audio room
- Connected to high-end equipment (Trinnov Altitude 16)
Key priorities:
1. Ease of use and management
- As close to plug-and-play as possible
- Minimal technical maintenance required
- User-friendly interface
2. Reliability and support
- Strong user community for troubleshooting
- Good manufacturer support
- Proven, stable solutions
3. Quality
- No compromise on audio/video quality
- Smooth handling of large libraries
- Future-proof for growing collection
Currently considering:
- NAS: Synology DS1522+ or QNAP TS-h973AX
- Theater: Zappiti Pro 4K HDR
- Audio: Lumin or Antipodes streamers
- Software: Roon for audio, Emby for video
Questions:
1. Are there more turnkey solutions I should consider where budget isn't a constraint?
2. Which combination would provide the most seamless, reliable experience?
3. For those with similar setups: What's the most hassle-free configuration you've found?
4. Are there any premium all-in-one solutions I'm missing?
5. What's the most robust setup for minimal maintenance?
I am looking for real-world experience, particularly from users with large libraries and high-end systems. Priority is on getting it right rather than cost. Thanks Guys!
What does
@gene and
@Matthew J Poes use for the movie and audio collections?
