need advice for a pair of bluetooth earphones
sfuerig
I want a pair of bluetooth headset which can match with my iphone5 or similar devices, so I am hoping some can give some recommendation.
1. I am not sensitive to sound, so no need for the top quality headset. i would like to use it for phone call or listen to music when jogging, so it must be a bluetooth one.
2. about the battery, it would be better that I can charge it directly. I appreciate that if someone have the personal experience of it, just tell me the feeling of using it.
Currently, the Avantree Sacool bluetooth stereo headset seem to be a good choice for me, proper price and positive reviews, cheaper than Amazon. I just want to have more options. I am not sure about the overhead kind, those seem not so convenient. But ear-hook of single side is acceptable.
just give me some recommendation of the same price group, my budget is about 50$.
Thanks.
G
Galoot
Save some more cash, up your budget, and get the jay birds blu buds. Sound great, fit well, and you can use them for everything from working out to casual listening.
sfuerig
Thanks a lot, but the earphones you recommended is the overhead kind, i have never used that , will it be strange if I wear it to answer phone calls
BoredSysAdmin
BoredSysAdmin
I think you got it wrong, you wear the band around your neck, not on overhead. And if you wear a shirt with high collar they are practically invisible
