Okay trying to decide on my first system, have narrowed it down a little but still could use some advice or suggestions. For the receiver I'm kind of torn between the Yamaha RX-V673 and the Onkyo TX-NR616. I'm pretty set on the front and center with the Infinity Primus P363 and PC351. Now for the rear I'm thinking either Klipsch Reference RS-41 II or the Polk Audio FXi A4. For the middle either the Bose 161 or Infinity Primus P163. And I have no idea on the sub looking for affordable "quality". Like I said new to home theater and will take suggestions I've just been going off of customer reviews and such.
Welcome to the forum...
I would scrap the entire list, lol..
Is there a specific reason you want the 616 avr?
Also check out the new Pioneer series 2 speakers, IMO they blow the Infinities away for less money..
As far as a sub, we will need some room dimensions.. And what is your actual budget..
Also are you set on 7.1 and will it work in your room, I find it wont work in a lot of rooms since the couch is against the rear wall.. Plus I think 5.1 sounds better... especially sine loosing the extra speakers gives more budget to the rest of the system..
