Thanks for the quick replies! I'm probably going to pull the trigger today or tomorrow, so it's much appreciated.
I should have described the placement better, sorry about that. Each speaker will be going into a narrow cubbyhole (6"W x 32" H x 10" D) in the wall (~36" from the floor). I guess you could call it a shelf. These are perhaps six feet apart, now with an hdtv centered between them.
Unfortunately I can't really do in-wall (or on-wall) speakers, since there are paintings covering one of the sides, and apparently audio is less important than paintings are here... Perhaps something to think about for the future.
Floor-standing is also a no-go, since while the room is large, it has couches and tables and such placed so the floor around the screen has to be available for walking. IOW, if it was blocked off, people would have to walk the long way around the room. And since the tv isn't the only thing the room is used for, it doesn't make much sense to rearrange everything.
Also, to clarify when I said that cost is not an issue as far as these speakers go: I meant that when deciding between $150-$600 speakers, cost doesn't factor in for me. Cost does definitely factor in if we're talking $1000+ per speaker, and I'd probably wait till I have more money before going for something like that.
Anyway, as for the center channel, I'll most certainly go with whatever matches the front pair, but right now I need to pick a front pair that'll fit.
As far as brands go, I'm aware that many of the companies of the speakers I listed make fantastic and beautiful large floor-standing speakers. I've even heard some of them... But I'm at a loss when it comes to these small speakers.
Thanks again for the replies!
