Hola benr-
I've got that amp in a 2.1 setup. I've tried it each and every way, including w/ active crossovers. Currently it is driving some small sealed monitors directly, relying on the speakers inherent roll-off, with the second set of pre-outs feeding subs a line level signal. I'll try to answer your questions...
Hi all...
Questions:
- Does setup 1 cut the lower frequencies from the feed to the front speakers? Is this generally a good thing?
The line outs on that sub are most likely unfiltered, usually intended to feed more subs. I don't know for sure regarding that Wharfedale, but chances are it has no high-pass filtering capability.
It is generally a good thing to high-pass your mains, but without an active crossover you won't have that option. Is it necessary? Not really, but there are gains to be had by doing so (better allocation of amp power, better dynamics, reduced risk to speakers...). Since those B&W's are ported, I thought I should mention that I've had better luck blending sealed mains with my sub. If it doesn't cause them to roll off objectionably high, you may try plugging the ports (thus losing 1/2 octave or so of extension in exchange for a little wider safety margin). I would consider 80hz to be highest acceptable minimum; if you need to cross your sub higher than that you could be able to localize it.
- In 2, the Pre-out1 on the NAD352 is stereo so I can only achieve this using a stereo connection - or can I use a mono sub lead from only one of the pre-outs to one of the line-ins? Threads elsewhere on this forum advise against Y-splitting.
The pre-outs are stereo, so connect both to your solo sub. Just use whatever interconnect is handy, no need for a y-splitter. It's ok to use y-splitters to divvy up an output to several amps, for example, but you're talking about blending L and R into one here; let your sub do that. You'll have the chance to run stereo subs down the line if you want, in which case each one would only be fed it's corresponding channel.
Twin subs rule, by the way.
- Do both 1 and 2 allow the sub volume and tone to be controlled directly from the amp?
Both sets of pre-outs are controlled by the volume control. Only pre-out 2 on the NAD is independantly variable, and you have to manually change output level on the back of the unit. I use the variable outs to feed my sub as it gives a much better way to calibrate sub level than the gain on the sub itself, which is way too easy to over-do. Set the gain on your sub slightly hot relative to the main speakers, and use the variable out trim it down in fine increments.
You will have to adjust the sub's low pass filter separately, on the sub itself.
- Would a standard stereo auxiliary cable be suitable (it's going to need to be long - 15ft or so)? Because I can't find a stereo sub cable and I don't especially want to spend double if I don't have to.
Many thanks,
Ben
Yes...while you probably want a shielded interconnect for such a long run, don't waste money on boutique cables. Try Blue Jeans or Monoprice online, or your local electronics repair/wholesaler/hardware store. The NAD's pre section can push enough juice that such a run is absolutely no problem.
