Bevan
Hi, hope someone can help with this decision I need to make.
Both options would cost about the same. My main consideration is stereo perfrormance.
Would seperation the pre and power stages(763+272) give better 2 channel performance than the 773? The 773 does seem to offer a bit more power in two-channel than the 272 if I'm not mistaken?
If I was to later get the 163 as a pre, would this improve 2 channel sound to any extent over the 773? and would it then be better I had the 272 or 773 as power stage?
thanks for any feedback
bevan
bevan
