You will find the same kind of jump in Denon, Pioneer Elite, and Sony ES models. You will not find the same (that is, much smaller) jump in NAD and HK models, except for their flag ships such as the HKAVR7X00 and the NADT773.
I don't know why neither, but I can only suspect that some manufacturers may focus on producing "honest" all channel driven power. In doing so, their cost increases due to the larger power supply (transformer, capacitors, rectifiers etc.). To offset the increase and remain price competitive, they may have to lower the cost of their amplifiers and heat sinks. Of couse I am only guessing. If you take HK for example, they apparently run hotter, and generally use a fan to help keep things cool. Equivalent (price wise) Denon and Yamaha models do not need fans, indicating they probably have relatively more powerful amplifiers, and better heat sinks. NAD and HK models are usually heavier, has very high instantaneous current rating, evidence of having larger power supplies.
Given that there is only so much to spend on building a receiver, I believe tipping the balance (of course only to a point) towards the amplifier sections is correct, as most audio source including 5.1 channel, do not require all channels to be driven to the same level. If it does, it would likely be for a short duration. Any decent quality power supplies have very generous overload capacity anyway. So it is better to spend more on maximizing the amp section so that each amp has the highest possible unclipped power output.
