NAD C720BEE Receiver
panicphan6
how does this receiver match up to the denon 685? i have a pair of rti8 towers...which receiver would you recommend out of the two?
panicphan6
i returned the polks and got the primus 360s..which receiver will do a better job, the nad or the denon dra-685?
G
garthr
Either one will do just fine. But no one can answer the question but you. The only way to find out for yourself is to buy one of each and try them in your home...... not someone elses home or retail studio..... your home...... where you are comfortable and familiar in your surroundings.
I've auditioned a Denon DRA-395,which I found to be rather lifeless, anemic on the low end and a generally painful edge to the sound. I doubt the 685 is dramatically different.But, that's me, my ears and my home,your results will be different.
The C720BEE I've not heard, but it's amp section is the same as the C320BEE amp which is generally regarded as a well rounded unit. Again, opinions can be cheap,try it for yourself.
If you're in the USA, try buying the Denon from Crutchfield. They have a excellent return policy if you need it. Free shipping to and from to boot.
Good luck , Garth
billy p
billy p
The Nad you're speaking of is a 2 channel stereo receiver the denon dra 685 is similar.The denon avr 685 has a 6.1 H/T amp section. I would go with the nad 720 if for stereo alone, nad is regarded as one of the best and denon for H/T! :)
