n00b + first home system
mraman
Hi all
I want to put together my first home A/V system. I have my heart set on Athena AS-F2.2's ($399 from audioadvisor).
What receiver goes well with these? I've read in other posts about:
Onkyo SR502 (SR504 is the current version - $250-300)
NAD C370 (too expensive for me at $599)
NAD C352 (still expensive, $500 quoted)
Harman Kardon HK3480 ($250 or so)
Any other components I should invest in? Should I splurge on a dedicated CD player or will a DVD player output suffice (I have a really cheap DVD player, and I don't want one component to bring down the quality of my setup.
By the way, my musical tastes tend towards rock and heavy metal.
Thanks for any input
Regards,
Madhu
tubesaregood
Any of those will be fine in my opinion. You can just go with the DVD player, too. I would probably look for at least a better one of those, then, if yours is REALLY cheap. In my opinion, the main quality issues are with the speakers and the amp/preamp. If you connect the cheapest DVD player to a good setup, it will sound good. There IS a point of diminishing returns if you get my drift.
jcPanny
jcPanny
Receiver options
First, are you building an HT or do you want a 2 channel system?
The HK you list is a stereo (2 channel) receiver. For a start to your HT, check out the Yamaha HTR-5960 or 5860 for about $300. I have the HTR-5860 and recommend it.
The digital audio output even from a cheap DVD player should be fine. The receiver will do the processing and D/A conversion.
If you have an HDTV, save for an upscaling DVD player like the Oppo DV970HD. I have this one and recommend it.
Also in your price range, check out the Onix X-LS speaker. They have a floorstander version comming out next month for $330/pair.
If you go with Athena, I have an AS-C1.1 center channel I need to get rid of. Let me know if you are interested.
N
Nick250
I would go for the Onkyo because I have read about NAD reliability issues, though the HK may be fine too, I am not familiar with it. There is no real advantage to spend more that what you pay for the Onkyo. As far as I know there is no advantage to dedicated CD player, so you are fine there. If anything, add to your speaker budget. They are the heart of your system. As I always say, cheap out anywhere in your system but the speakers. I would suggest pushing your budget on speakers, but not on any of the other components you have selected.
mraman
Thanks for the input.
I'm not sure if I want to go with a 2-channel or Home theatre system. I'm not into the whole HT surround experience, it's not a priority for me. That said, all things being equal, I'd probably want to keep my options open in the future.
From your posts, I conclude:
- Stick with existing DVD player, use digital outs to connect to receiver
- NAD is a no no for reliability and price
- HK is a 2-channel, so that's out (since I haven't heard that it's any better than the Onkyo)
So, now it's between the Onkyo SR 504 and the Yamaha HTR5860
jlyttle
Take a look at the Onkyo SR604, I love mine.
http://www.crutchfield.com/S-FSKNAwyATmc/cgi-bin/ProdView.asp?g=10420&I=580TXS604S&search=sr604
It is $499 now, but I bought mine from them 3 weeks ago for $399 and free shipping. Shop around, but it is a fantastic unit.
http://reviews.cnet.com/Onkyo_TX_SR604_black/4505-6466_7-32008415.html
Contrary to what the review says, if you have an HDMI cable box and DVD player like me, only 1 cable needs to go to the TV from the receiver. BTW, I also own the Oppo player and can't think of a better one in the price range. Highly recommended.
AmpItUP
The Harman Kardon HK3480 is okay since it works well and is priced cheaply too.
__________________
McIntosh MCD201 - MCD201 SACD/CD Player Catalog by McIntosh Laboratory, Inc. for download
mraman
How about an Onkyo TX SR 573? It's on clearance for $220 at the local Circuit City
I've decided that I would like future expandability, so I'm ruling out any 2-channel receivers for now....
UNLESS, someone tells me that the sound quality from a dedicated 2-channel is much better than that from a 5.1/7.1 of similar price
Rock&Roll Ninja
Rock&Roll Ninja
I've had a NAD c370 since 2000 and its behaved flawlessly. But it is a 2-channel integrated amp.
mraman
Update
Hi all
Thanks for the input. I took the plunge and got a new HK3480 for $230 shipped from Amazon. Yes yes, I said I wanted surround, but I didn't want to go with Onkyo (IMHO, HK is a bit more upmarket, and I have heard that HK "sound quality" is better than Onkyo's). The closest surround receiver I would have settled for would have been the AVR247, which is $500 or so. In any case, I don't _have_ surround speakers, so I thought I should save up for later (1-2 years), when I can get a mature HDMI receiver with surround at a decent price.
In any case, I set up my Athena AS-F2.2's ($400 shipped from audioadvisor.com) with the HK, and I'm deliriously happy :) :) :)
Madhu
