Shopping for Headphones: Which are Right for You?
admin
Audioholics Robot
Staff member
What is most important to you in a set of headphones? If it is sound quality, any of the options can sound very good, though over-ear models generally hold an advantage. If fit is your primary concern, then you'll need to look at how you use the headphone (on the go, at home, while exercising, etc.) to determine what will work best for you. We've assembled a Cheat Sheet to help you narrow down your choices along with a helpful guide on the different headphone types.
Read Shopping for Headphones: Which are Right for You?
What headphones are you using and why? Let us know.
