Form Factor and amp questions
I even started a thread last fall on this......
http://forums.audioholics.com/forums/amps-pre-pros-receivers/amps-pre-pros-receivers/amps-pre-pros-receivers/amps-pre-pros-receivers/87016-class-b-vs-class-d-amp-comparisons.html................and got some subjective responses from knowledgeable people, but sparse direct comparisons between class A/B and class D amps. Also noticed that the vast majority of people who have tried both amps seemed to prefer the class A/B ones, primarily for the looks as opposed to the sonic qualities, but not always.
When i was speaking with Dennis from D-sonic, The form factor was one of my direct questions. If I like the amp, I receive. I am going to transplant it it to a custom made case.(
https://www.hammfg.com/dci/products/accessories/rm).
All my equipment is rack mounted. I understand if amp makers have custom size mono amplifier. But as soon as they get into stereo/multi-channel, it seems to make sense to keep it a standard form factor. In fact that is the whole reason I am changing amps. Having the two Emotiva Xpa-1s, and a Xpa-3 plus a Sherbourn cooling unit, takes up 16 rack units. It also generates a fair amount of heat. But sound quality, is still of foremost importance to me. So thus the dilemma, and or change possibly to class D. So if i like what i hear, and they perform well. I will reduce the rack unit space to 6Ru.
There are very few other options in this category. Cherry Ultra's, Anthem Statement M1's. Both of these are rack mountable, but also very expensive in my book. Also the M1 has had some less than favorable reviews. (
Anthem Statement M1 monoblock power amplifier Measurements | Stereophile.com). Once again manufacture specs vs specs of a reviewer. Also notice huge dive after 20khz, even though manufacture specs are 5Hz–45kHz. I hope Dennis is a less misleading in his specs.
I have yet to see a professional review of the cherry amps. Which doesn't matter to me as they are out of my price range. But what does interest me, is there design. Back to my previous post. My Emotiva Xpa-1 amps have 1,200VA toroidal transformer, 120,000uF filter capacitance. The Cherry Ultra's have 1800W Toroid Transformer. Not sure of there capacitance. The Cherry Ultras are only rated @ 400w into 8ohms. So why the massive power capability and HUGE transformers(see link below)?
In my previous post, i was wondering about the reserves of the d-sonic amp.
Does there transformer introduce noise?
Would larger capacitance increase there headroom? (See pictures of cherry amps huge capacitors,
https://www.digitalamp.com/gallery.php)
Because of there efficiency, is the capacitance a non factor?
Take for example, the intro to Dire Straights - Money for Nothing. At reference levels, think of how an amp would have to have quick burst of current.
Is there a test to see what an amplifiers quick burst (20ms) is capable of?
Do class D and Class A/B amplifiers differ in there abilities in this area?
These are the questions i still have about Class D amps. Specifically D-Sonic amps, as i just bought one. All of the other amps i have owned, have had a clip indicator. D-sonic amps do not.
So once again thank you very much Gene for reviewing these amps. And i hope review covers these questions.
