LG EA9800 Curved-screen OLED Television Preview
admin
Audioholics Robot
Staff member
What do you think about LG's EA 9800 curved OLED TV?
We saw it at CES a really liked the three of them in a row, but taken one at a time the effect seems pretty minor.
Discuss "LG EA9800 Curved-screen OLED Television Preview" here. Read the article.
smurphy522
smurphy522
Funny how I recall TVs going for the flatest screen years ago (Panasonic Superflat, Sony Trinitron come to mind). Of course those were the days of CRT TVs; remember those? I understand the theory of this inner curve but in something like a 50" panel I am not so sure it makes that much of a difference. I smell snake oil.....yup that's definately snake oil (at least until I read a proper primer on the technology and its benefits in smaller screens).
W
wiyosaya
While there is no info on pricing and availability of the curved model, LG's 55EM9700 is said to be coming to the US in March of this year for $12K. Given the missed market dates for last year, I remain skeptical.
The one OLED TV that I find exciting is the printed 56", 4K prototype that Panasonic displayed at CES. IMHO, OLED printing technology has promise for bringing OLED to the masses at inexpensive prices. Unfortunately, Panasonic apparently mentioned nothing about availability or pricing on this model.
BMXTRIX
BMXTRIX
Curved screens are stupid. STUPID!
This is worse than a 42" UHD display viewed at 12' away.
The entire point of curved screens is for cinema use where it helps to create an even viewing pattern for light as it reflects off the screen. It makes the angle, in reference to the projection, more consistent, and therefore you get a more consistent image across the viewing area within a theater.
This would actually be of some benefit to large format LCD displays which have uneven viewing angles.
But, OLED is supposed to be similar in plasma with a phenomenal viewing angle range and no drop off regardless of viewing position.
The only reason to curve the screen is because the actual technology if flawed in some way and therefore needs it. Which means you should just stick with plasmas and LCDs.
I always thought one of the coolest things about OLED was the phenomenal (plasma rivaling!) image quality which has been promised in a display that is just a few mm thick. Ship it within a in-wall back box and let me hang it on my wall thinner than any photo currently on my wall.
No - better yet, curve out this skinny display several inches so I can catch on it as I walk by and knock it clear out my window.
Just insanely silly.
Pyrrho
Pyrrho
Is the curve supposed to make one think of Cinerama? Basically, it is going to screw up the viewing angle for anyone who isn't dead center. It is a really stupid idea for a small screen (small relative to a theater). It will make the side of the screen on which one is sitting look like one is more off-axis than one is. Granted, it will make the opposite side better, but it will make for a very uneven viewing experience for anyone who is not on-axis.
From the article:
Like a high-end movie theater, the entire screen surface is equidistant from the viewer's eyes, removing the problem of screen-edge visual distortion and detail loss.
That will apply only to someone sitting in the exact center of the screen, and will make things worse for every other place.* If you watch movies alone, then it might be good (assuming your seat is perfectly centered). Otherwise, it is a really stupid thing.
_________________________
* And it will only really be as described for that person if it is curved both horizontally and vertically, a bit like a bowl with the center of the screen being the bottom of the bowl, and one will have to sit at a precise distance as well for each part of the screen to be equally distant from one; the closer one sits, the more curved it needs to be to have the effect of each part of the screen being equally distant from one. So there will be a precise distance for whatever curvature they select in order to actually be equally distant from every part of the screen. This means that one will have to very precisely position one's seat in order to get that effect, and so it will be wrong in virtually all cases in which people use the TVs. I doubt that they will bother to tell people the right distance for the effect, and so it will involve some calculation to get it right, and almost no one is going to do that when they set up their one seat home theater.
