How much power saved?
"By transferring the power robbing, low frequency load off of your speakers to the dedicated powered subwoofer, you reduce their workload as well as that of your receiver/amplifier."
Any way to quanify the amount of power saved for a typical bookshelf or tower speaker if crossed over at 80hz? Is almost all the watts in the system used by the woofer and little is needed for the tweeter? Is it enough that anyone with a decent amplifier - say emotiva x-series - has wasted their money when a upa series would already be far more powerful then the bookshelf or even tower can handle now that the low frequencies are crossed over?
