The last time we touched an AudioEngine A5 speaker was back in 2006. Now 5-1/2 years ago we felt that the A5's had, and I quote "superb build quality, finish, and high-end sound quality". Well, a couple things are different - but mostly not much has changed. First of all, if you loved the AudioEngine A5 speakers, you can still get them - in fact, they're $50 less then they were when we reviewed them. The A5+ speakers, however are more or less a model that is designed for multimedia or active monitor use. They lack the odd top USB charger of the A5, instead moving it to the back. They also dropped the auxiliary power outlet, which was perfect for the popular Apple Airport adapter. What they added was a pair of RCA inputs - and they made the RCA outputs variable - so you can connect them up to a subwoofer and get extension well below 50Hz, which is about what you can expect from the A5+ speakers on their own. For multimedia speakers, the extension of the AudioEngine A5+'s is going to give you some excellent real-world low end not found on most other 2.0 systems. But like we said - add their S8 sub or a similar model and it gets even better.
Discuss "AudioEngine A5+ Speakers Video Review" here.
Read the article.
