admin
Audioholics Robot
Staff member
Emotiva has once again proved with their new X-Ref 10 that they can design a subwoofer with the same no-nonsense rugged build quality they do with their amplifiers.* You simply cannot break this sub no matter how hard you drive it. The X-Ref 10 is a beautifully-crafted, potent, and compact subwoofer with many useful features including an adjustable PEQ to ensure you get the best performance out of your subwoofer when integrating it into your room. Take your time to set this baby up and utilize all of its features.* It will reward you with good clean bass that well engineered sealed subs are known for. Emotiva's free shipping and generous 30 day return policy makes this value sub a no brainer if you're in the market for a high performance sub in a compact footprint to please your significant other. The Emotiva X-Ref 10 achieves the Audioholics Bassoholic "Small room" rating, which means that this sub is recommended as maintaining adequate headroom in small sized spaces less than or equal to 1,500 cubic feet and/or users who usually listen at a moderate volume level.
Discuss "Emotiva X-Ref 10 Subwoofer Review" here. Read the article.
