Housed in a sleek, black case, the Apple AirPlay equipped G-17 Air sports two .75" (1.9 cm) aluminum diaphragm compression drivers mated to dual 90° x 90° square Tractrix Horn-loaded tweeters. This allows you to stream content from your iDevice (anything running iOS 4.2 or higher) or your iTunes from your computer (PC or Mac) over your home network. Not to leave out the other phones, any Android-base phone with the music player app can stream to the G-17 Air as well. Since even the most tech-unsavvy person has been able to figure out their iPhone, pressing a button to send it to the G-17 Air shouldn't present much of a problem. Add to that the portability of the system, and you have a whole-home system that you can take from room to room (or change locations for different events).
Discuss "Klipsch Gallery G-17 Air AirPlay Speaker System Preview" here.
Read the article.
