Premier Debuts Tilt, Swing-out Mounts and GearBox Storage
admin
Audioholics Robot
Staff member
Three new products came out of Premier Mounts this week, including an modified version of their P-Series flat-panel wall mounts, the X-tilt. The new mount, the P4263XT will be debuted for the first time at InfoComm 2011. The new tilt mount is very similar to the company's P-Series, but adds extra downward tilt - up to 15 degrees, and more upward tilt - an unusual 10 degrees. They also integrated new quick release levers to make it easy to adjust by hand. Modified mounting brackets now come with auto-latching locks which will allow the back plate to quickly and easily fasten to the mount. They also added quick-release tabs to pull the monitor off the wall-plate when needed. It should speed up installation, and make the whole system easier to service. Overall, we've found Premier's flat panel mounts to already be pretty easy to use - and by "easy" I mean "quick and adjustable".
Discuss "Premier Debuts Tilt, Swing-out Mounts and GearBox Storage" here. Read the article.
