Thank you Mark for a great review of what's out there..............Pursue the TRUTH!
In response to kesando's post I think that the Emotiva Ultra Series 10" sub may be a more comparable one for the Lava LSP12 to go up against. It appears to be more in line performance/rating wise and there is only $9 US separating the two at this date of posting.
Hey Gene, see if Dan can send you one for a comparison test in a "Budget-Sub Rumble"!
The Lava LSP12 and Emotiva Ultra 12 ground plane measurements were not taken in the same environment (the Emotiva outside and the Lava in room), even with a +3db advantage for the Lava the Emotiva kept right up -from what I could tell. Also to note that the Emotiva has a more flexible tuning capability with a variable phase.
Kudos to Lava for offering such a low priced product with high output (in the most usable and noticeable Sub bands) and little port chuffing.
Maybe a small paragraph or two covering the types of speakers these subs would go best with is a nice adder for future sub reviewers to include - just an idea. Also noting what equipment the reviewer used the product with and the room size is always helpful. (I did note the call out of: "All listening tests were done with the LSP12 integrated into a 7.1 HT system, powered by a Denon AVR and EQ’d using the Denon’s built-in Audyssey system. On the sub itself, phase was set at 0˚, gain was at 50%, and signal was fed in via the bass managed LFE jack.)" Still kinda generic for a Audioholics review.
Please note I own none of the products mentioned above.
