The 2.2i was rated down to 40-20kHz @+/- 3dbs with useable bass down to ~35hz and rated 89dbs in room. The 5.1 are rated between 50hz-25kHz @+/-3dbs and ~90dbs in room. The 2.2i mid range and tweeter were self chambered reducing any interaction with other drivers...Although the reviewer talks about the overall fit and finish of the v5.1 and their build qualitly weighing in at 12lbs...as that of a tank don't even come close to the 2.2 which weighted ~30lbs each. Every aspect in their design was thoroughly thought out by the engineering team..IMO....Here is a cut away of the 2.2>
http://www.who-sells-it.com/cy/audio-products-international-corp-1386/energy-speaker-systems-veritas-i-series-brochure-5304/page-10-fullsize.html
Check out your local FS but I'm sure the 5.1's will sound very close to your 10's..if you still have them...
I've never seen an older Veritas speaker before, much less heard one, although I'm aware of their sterling reputation. I mentioned before, that I think Klipsch is just milking the name for whatever they can get out of it, without investing much.
I still have the 10's, but they aren't in use right now. I love my Studio 20's, but the difference between them and the 10's certainly isn't night and day. Bass performance would be the most noticeable difference and I would say that at higher spl the difference becomes more apparent. As for value for money - no question, the RC-10's win hands down, because they can be had for far less than MSRP.
I still have the 10's, because it's just so hard to part with them! I do have a potential sale lined up, but I haven't pursued it too vigorously. I have difficulty parting with any of my audio redundant equipment. I still have a pair of Mordaunt Short 902i's that I need to sell also. Then there's the 20-year old pair of Sound Dynamics 200 Ti's - one with a busted tweeter that I can't get a replacement for. They should be disposed of, but I can't bring myself to do it!
I need an intervention....
But, I digress. I would have to see some comparitive measurements between the new Veritas and the RC, as well as listen to them side-by-side, before I would even
consider spending more for the Veritas.
